-   -   Exhaust leak sounds like a broken engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/146937-exhaust-leak-sounds-like-broken-engine.html)
cstreit 02-03-2004 07:48 AM
Just wanted to pass along my latest fustration/scare.
I just finished assembling this 3.2L short stroke engine a week or two ago. Got it started and heard this rather frightening noise that sounds like a broken rocker or some metallic object banging the valve covers quite hard.
Turned out to be a small exhaust leak right at the head because a few of the exhaust flanges were warped... I only noticed this because a) the motor ran smoothly, not like one with a broken rocker/bent valve, b) a stethascope revealed no internal engine noises.
So I went underneath and found carbon trails by the exhaust flanges. Heated and straightened them and replaced the gaskets and now she purrs like a kitten -- A MEAN and ANGRY kitten. :D
Just an FYI
MotoSook 02-03-2004 09:09 AM
should have disassembled it and started over! :D
