I've been following this thread from the beginning and its been a dandy,....:)
Since I've been doing this for a living (building 911 race engines) since 1976 and have a LOT of time at our flow bench, I'd just offer that its far easier to ruin a set of 911 heads than improve them, regardless of how large or pretty they might look. I would also caution anyone not to draw too many similarities or conclusions between 911 heads and cylinder heads from other engines. There are far more variables at work here than meets the eye,...:) |
I'll echo Steve's comments here. I'm certainly no expert on head porting, but I did interview many experts in the Porsche field, and also did quite a bit of research on the subject. The Engine Book is light on head porting info because I couldn't really narrow down useful information to put in there. Flow rates for all heads weren't available to me, and the "black art" of head porting seems to be a well-kept secret that not too many people are willing to share (Walt didn't want to talk about his particular techniques on the record).
For those who need their heads ported, it's not really the actual porting that is tough - but knowing what and where to cut and remove. Just like an oversized exhaust can kill HP out of an engine, too big of a port job can also remove HP when you're actually trying to increase it (running too large of a carb too can cause problems). Everything has to be balanced with itself. For me, I would never do my own porting - maybe some polishing, but not porting. There's too much risk in messing up a set of heads to make it worthwhile. -Wayne |
Lest people be confused about my intentions, I agree that guys like Steve and Walt have certainly learned a lot more about porting then the rest of us will have the opportunity to understand -- especially as Steve has said by actually experimenting with 911 heads. They've learned what they know through hard work. I certainly agree that if you want top shelf head performance for your race car -- I doubt that you could do better.
By the same token, any product or service which is shrouded in secrecy risks being polluted with "snake oil". Buyer beware! I am of the belief that a lot of people spend a lot of money getting their heads "ported" when they don't have a clue what they are getting or if it will even do them any good. There are a lot of people willing to take people's money to run a grinder around the port a couple of times and return a "ported head -- worth a gazzilion HP" when in fact the changes made have not improved the performance of the motor, let alone degrading it. Now if people want to spend their money that way because it makes them feel good -- go right ahead. I just figure that public discussion and sharing of data on the subject might be worthwhile to people who have to invest their money wisely. |
At least with CIS engines, I believe it was Steve who said it makes a very small difference in performance when the smaller diameter heads and intake ports of the later '80-'83 U.S. 3.0 engines are ported to the larger diameter size of the '78-'79 U.S. engines or those of the ROW 3.0 engines. YMMV.
John, haven't been here for a while.
Our Spam filter threw the notifications into Quarnteen. I was wondering what happened. It was like the PP board went dead. Anyway there are many differences from the 83 US and the 83 US CIS. The most obvious is that the US was then K-lambda with the o2 sensor and computer. ROW kept the same basic design as 79US but they continued to tweek it over the next few years. K-lambda air meters have a cone with a single plane. ROW is stepped as most of the metering is done by the shape. It's shape is steep near idle then flattens during light acceleration and then steep again at the top where the plate rises whit higher air flow. This mixture is richened for acceleration by a vacuum mechansim in the control pressure regulator which lowers control pressure. In the later US CIS K-lambda the fine tuning of metering is done by the computer that effects the pressure in the bottom half of the fuel distributer. The control pressure regulator was then simplified and the cone in the air meter is simplifies and does not have the steps. I know there is a significant difference in the flows between the two as well as the 79 US. Although the 79 is simular in design the Fuel distributer does not flow as much. How do I know? When I bought my car it had the wrong FD on it it was the US 83. At the time I could not find the 83 ROW FD so I replaced it with the next best thing. 79 US FD. This worked better than the 83US, but still ran way too lean at mid range flows. (I attemped to adjust this by lowering the control pressure, this is a little known fact that it can be done.) Even lowering the control pressure did not allow the 79 to flow enough to meet the demmands of the 83ROW air meter. My conclusion (Untested) is that the 81-83 ROW FD and Meter do flow more than both the 79US and the 81-83 US. The 81-83 ROW maintained the larger air box (Including the cold start valve manifold) and the larger intake runners and my assumption the larger intake ports. My guess is there was a good reason for doing this. Performance is my guess. I do agree with the experts that maybe there is litte gained by attempting to get increases by just porting the heads, but I think there was a performance advantage in the complete system used on the 930/10 engine over the emissions restricted US 930/16. Can anyone please confirm the port size on the 930/10 engine? I just have to know. |
I must say, yet again, that the question that started this thread was (and remains): Is it possible to COPY what Porsche has done and is known to work? If I want an S motor, then S ports should be just the thing. Given a physical model, it seems to me that a copy could be made without a flowbench, PHD, or eye of newt.
Scott;
I think that you will continue to get a split decision on that. I know that I've shared what I know for data. So I guess the decision is now yours. |
It's your quest. It looks like it's possible.
Once the metal is on the floor, let us know how it went! Good luck, I really hope it works! |
My book says 34mm intake, 35mm exhaust.
-Wayne |
I thought he was asking about the ROW late '80s 3.0. |
I have a plan! I'll find a junk T head and a S head to use as a model. I will port the T head, and have both flow tested. Either it will work or it won't. This scheme allows me to gracefully bow out if the going is rough, or if I get poor flow. Anyone have some junked heads?
On T heads, I would suggest flowing them first, you will most likely find you don't even need to port them! (unless your building a race engine that turns over 8000 RPM) How do we know this? The air fuel ratio is well known, for max power on a fuel injected engine, its about 13 to one. That known, the engine displacement known, the max RPM known ( you know this answer based on your budget and what you are doing for rods, pistons, valves....and almost certainly it is less than 8000 RPM for a street car) and you know EXACTLY how much air you need. If your heads flow this much air, your done. Knowing the HP produced by this quantity of fuel will also give you an almost exact ammount of HP you will make. A program like Engine Dyno 2000 is most usefull for this kind of thing. To many people hide behind the smoke and mirrors and snake oil used to sell this kind of stuff, its not magic, and once you look close at it, not all that difficult to understand, after all even an automechanic can understand it. ( Slam was toung in cheek fellas) Those that take the time to investigate and learn this stuff will be amply rewarded, the rest will continue to pay thru the nose. And in the case of head porting you may NOT get what you pay for. I am going to give one of the porting secrets away now. Even though they make lots of bucks doing it, the people that do it, and are very good at it, and give value for the buck, HATE doing the job, probably even more than cleaning the bathroom, even for all that money. |
Ok, if porting is viewed as a sin, but port matching is perfectly acceptable, is it possible to match the inake port of E head to that of an S? Or how about matching the port of E head to that of an S manifold? Would this be considered an acceptable practice that stands to gain more than it can damage? Afterall, all I'm trying to do is match the port to the 36mm size.
Mismatched port sizes are always bad. An absolute mininum would be to match the ports at the junction. A better solution would be to use the same size ports thruout. If you want to see what your ports look like make a silicone mold of them like this:http://forums.pelicanparts.com/uploa...1077343057.jpg
This is a full race intake port for a Porsche 912 or 356 engine. It flows 195 cfm at 28" of water at 0.5" valve lift Thats enough for almost 200 HP at 8000 RPM for a 1725cc engine. This kind of porting isn't for a street engine, unless you don't care if you can't use your engine below 3500 to 4000 RPM. To answer your question directly, DON'T mis match ports. Use the same thruout and don't do it yourself, unless you have a flow bench, homemade or otherwise. The S ports are 9 tenths myth, and one tenth performance. Trying to make an E port an S port, will most likely yield worse performance, even if you do it right. Street perfromance depends on the low end, not the 8000 plus performance. additonal info, it would be better to match a S manifold to an E head as the port velocity would increase, rather than decrease as it entered the cylinder. |
Note that every stock head that I've measured (and the 912 head that you showed) gradually expanded from the manifold face to the bowl behind the valve. Everyone who suggests a straight plunge (parallel port walls) or walls that converge at the bowl (as you describe) is suggesting something very different and apparantly feel that they know something that Porsche didn't. Or maybe they are just missing some subtle points which Porsche knew. Why did they do that? I don't know but a couple of SWAGs are... a) They didn't want the velocity to be so high going around the bend in the bowl b) Cross Sectional area. In order to maintain the cross sectional area in the region of the valve stem and boss, the overall diameter needs to be larger. c) Flow. If you are going to expand the diameter, you can't do it suddenly lest you stall the air near the boundry layer, so a gradual change in cross section is required. d) I've got a couple of other hair brained ideas too which I'll keep to my self lest I confuse others as much as I've confused myself. Check out the video(s) in this post to get an idea of the types of things going on in the ports in regards to pressures, speeds and timing. |
I’ll third Steve and Wayne. John and Jack have great information.
Bigger is not always better, at least on ports and associated plumbing. Remember, the flow bench measurements are static, continuous flow and are indicators. The air/fuel flow in an operating engine is discontinuous pulses. Does the “closing of the valve” pulse reflect off the transition from the intake runner to the airbox? What are the intake reversion issues? Additionally, the CIS (kontinuierlich) continues to flow fuel from the nozzle even when the valve is closed and there is no air flow. Where does that fuel go and how is it re-atomized? Who has insights on the dynamics of the situation? Best, Grady |
Everyone should look at and study John’s animation at:
http://forums.pelicanparts.com/showthread.php?s=&postid=1143536 This gives some idea of the complexity of the dynamic situation. Good post John. Best, Grady |
BTW Grady, I can't take credit for the automation. Only finding it on the web after reading the article in "Race Tech Engines". I'm not smart enough to have figured it out in the first place. :confused:
John,
“Not smart enough….” I don’t think so. I’ve been reading your posts. Your banter with snowman has enlightened many Pelicans. Regarding the animation: http://www.optimum-power.com/RET/unrestricted-9000-pressure.gif I Notice there are almost two pressure cycles in the intake after the intake valve closes. I interpret this as reflected pressure pulses from the intake valve closing to whatever discontinuity upstream in the intake (like the transition from the intake runner to the outside world.) This clearly has significant “intake ram effect”, note how high the intake pressure is just before intake valve closure. Before I spend too much time on this animation, what engine is this duplicating? Is it a computer simulation or direct measurements? What engine dimensions (bore, stroke, rod length, CR, valve timing, intake and exhaust runner length, RPM, etc.)? Can I download the actual data points? There is potentially some really useful information here. Has anyone done this for our nice little hemi cross-flow head? Best, Grady |
Grady;
Basically, the example was created as means to demonstrate the software's capabilities for modeling, even in the difficult case of an intake restricter. In two words, as a sales tool for the software. If my memory is correct, it is for basically a 1 liter 4-cylinder motorcycle engine. They demonstrate it at 2 or 3 engine speeds with and without the restrictor. In all cases there is an intake plenum. I believe that they have coorelated the software since they are selling it as an engineering tool, but of course they didn't provide examples. I did link the original web site at the bottom of my first post with the animations. In our case most early 911's are not restricted and don't have plenums, although the venturi on the carb'd models can act like a restrictor if the are undersized enough. CIS engines are a whole 'nother can of worms as far as I can tell. |
Hi John:
Just as a data point about plenums,......the OEM MFI air cleaner assembly acts as a resonance chamber (just like on all the 3.6's) and these engines lose power with individual air cleaner assemblies on each stack. Sounds nice tho,....:) |
Steve,
You are right on. The plates above the stacks on 906, 911R and later are reverberation plates. They reflect the intake pulse back to the valve. This is why an early 911S needs to have the air filter assembly. Best, Grady |
A comment about the shape of the port for a street car. I still think what I said about the narrowing of the ports is the best way to go on a street car. A race car is a whole nother story, as it will not idle or run well at lower RPM like a street car HAS to do.
The picture dosen't show both sides of the port. The port size dosen't vary as much as it would appear on this photo. Finally as I have repeatedly said, the Porsches are so good, you don't really have to do anything to them (unless its a race engine). This pretty well agrees with your statement on the subject. |
An analogy to how porting works, my own words:
Envision groups of cars, traveling on an eight lane highway, all even and going in a straight line and the highway is a race track to boot. A sharp left hander approaches. Most of the cars bunch up on the inside of the turn, the outside ones go on their way with much room to spare. A tire, part of the inside wall falls out onto the track. The inside cars have to slow further, and because the tire is obstructing the way, the next line of cars has to make way for them to alternately merge into the flow (really slowing things down a whole bunch) Another serario, a tire falls onto the outside of the turn, the cars there have ample room to go smoothly around the tire and no significant flow interruption results. This is a whole lot like air going around a corner. Small bumps on the outside are detramental, but not a whole lot, small bumps on the inside of the turn are major obsticals to the flow. I beleive this analogy is highly accurate. The opening and closing of the valves could also be analogis to putting on the brakes, the explanation a whole lot more complex. I will continue to attempt to explain , and I suspect that the exact same reasons are responsible for what we observe. Traffic, at rush hour, on a CA freeway, goes like heck, stops, then goes like heck. If you were to look at it at a distance you would see a series of bunches of cars, all stopped at the same interval, and inbetween cars going like heck, just to stop again. This is a real life standing wave. The same thing happens in the intake. When a valve closes, EVERYTHING STOPS moving, IT HAS TO, or the valve must fail. Think of a bunch of cars coming upon a landslide across the road. everything stops. The result is a whole bunch of cars piling up in a bunch. Being a race, as many cars as possible turn around and go back the other way. As they do they start piling up with oncomming traffic, untill they come to a total stop, creating another bunch of traffic, that is totally stopped.. This bunch acts like the bunch before it and creates another bunch the same distance in back of it and so on. The valve opens, the traffic clears, for a while, but still flows with bunches that were formed while stopped. if the valve closes at the right time the following bunch will fall thru and create a surplus of cars on the far side of the valve (tuned induction), but only if all conditions are perfact (ie at a single RPM or multiple of it). IF the valve closes at an inopportune time it will stop the entire next bunch, totally, and acutally suck power out of the flow, ie a suck out, or dead spot) Thats my first order cut at how things really happen. PS Since cars behave with some intelligence (except in LA traffic and NASCAR racing) the same example should be invisioned with parallel groups of evenly spaced ping pong balls. The inside corner gets very congested and any, ANY obstruction really makes a mess of the flow. On the outside a small obstruction only makes a small wrinkle in the flow as the spacing between balls is large and consequently there is lots of room to go around anything that gets in the way. PPS Wayne, I really wish spell check would work with Netscape. |
| All times are GMT -8. The time now is 04:32 AM. |
