-   -   2.8 short stroke question re: rods (http://forums.pelicanparts.com/911-engine-rebuilding-forum/148762-2-8-short-stroke-question-re-rods.html)
Tricky D 02-14-2004 05:01 PM
Which rods do I use, the 2.2 rods that go with the short crank, or the 3.0 rods that go with the pistons?
Scott Clarke 02-14-2004 10:44 PM
A 66mm crank requires the use of the 2.2 or 2.0 rods. The distance from the wrist pin to the top edge of the piston is the same regardless of application.
Tricky D 02-15-2004 05:27 AM
Thanks Scott. Fortunately I have the rods, just need to get them reconditioned.
Wayne 962 02-15-2004 11:43 AM
FYI, for everyone else:
- 66mm crank & rods
- 3.0L pistons
- 3.0 1976-77 Euro Carrera or 911 Turbo Case
= 2.8 short stroke...
-Wayne
Tricky D 02-15-2004 02:20 PM
Wayne,
What makes the 76-77 case so special, i.e., how do they differ from later Euro Carrera cases?
Wayne 962 02-15-2004 02:40 PM
Originally posted by Tricky D
Wayne,
There is no other "European Carrera" per se (I guess you can call the 3.2 European versions a Euro Carrera, but no one does).
The 1976-77 Euro Carrera and Turbo (Carrera) had an aluminum case that can accept any crankshaft from 1965 through 1977. This allows you to plug this engine into any 914-6 or early 911 without any modifications to the transmission or clutch setup. This also allows you to build a short stroke 3.3 for use in these cars, or a short stroke 2.8 as detailed here.
It's a very rare and useful engine case.
-Wayne
Tricky D 02-15-2004 02:52 PM
Thanks for the insight Wayne. Perhaps you might consider adding this explanation to future editions of the book (or did I just miss it)?
Tricky D 02-15-2004 02:54 PM
Wayne -
One other thing, if I may. Are there any particular case numbers I should be looking for, like 930/52, 930/02, etc.?
Thanks again for indulging me.
Rich
Wayne 962 02-16-2004 04:34 PM
Yes, you did miss it. See page 112 at the bottom.
-Wayne
Wayne 962 02-16-2004 04:35 PM
Wayne -
Rich
See Appendix A for the list of the Euro Carrera and Turbo Carrera engine cases. When I found my Euro Carrera engine case at Pomona, I had to run back to my booth to get a copy of my own book to look it up!
-Wayne
