Christian's Avatar
1970 911T Pressure Plate?
I am in the process of replacing my pressure plate due to distorted fingers (probably from sitting the last 20 years) and have found a replacement plate. My current pressure plate is aluminium and the replacement I found is cast iron. The type number is the same but the part number is different. Both are Fichels and Sachs. Can I use the cast iron and is the only drawback the added weight of the cast iron? I appreciate any advise from anyone who is more familiar than I. Thanks in advance,
Christian
1970 911T
1963 356 Super
Old 02-16-2004, 11:50 AM
Cast iron pressure plate will cause the moment of inertia of the clutch/flywheel system to increase. Engine will likely idle more smoothly but be slower to rev up and take longer for rev's to fall. Cheers, Jim
Old 02-16-2004, 09:13 PM
Christian's Avatar
Thanks for the advice. I thought that would be the case but of course I was hoping for the easy way out since a friend of mine has a cast iron plate collecting dust. Looks like I'll be looking for an aluminium one instead.
Regards,
Christian
Old 02-16-2004, 10:38 PM
Author of "101 Projects"
Wayne 962's Avatar
In general, it will make a minimal difference, except when you are revving the engine with the clutch disengaged. Adding the heavier pressure plate is equivalent to adding slightly heavier wheels (rotational elements of the drivetrain).
-Wayne
Old 02-17-2004, 12:48 AM
