Aaagghhh! Camshaft broke
Had to share this, I couldn't believe my eyes when I saw what happened. I was doing my sprocket alignment measurement on my 2.2 I'm rebuilding. Just retorqueing the left side camshaft nut. Had the wrench set to 120ftlbs (not even the 150). Everything suddenly goes bang!. I look down thinking I had fallen off the nut with the crowsfoot. Took me a while to realize that the whole end of the shaft had sheared at the root of the threads. I just could not believe it. Took me a while to process what I was seeing. Anybody ever had that happen or seen it before?
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 01-29-2004, 05:01 AM
Never seen or heard of that happening
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-29-2004, 05:35 AM
Super Moderator
cstreit's Avatar
I've seen them break in shipping, but not like this. You are probably quite lucky that it happened now, instead of later when your engine was together. Any area that is swedged down like the early camshafts is subject to stress risers in that area... ..for the same reason that torsion bars larger thatn 33mm tend to crack.
I would get a replacement one, then have them both magnafluxed...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-29-2004, 05:57 AM
Senior Member
Doug Zielke's Avatar
Steve.....*please* be so kind as to post some pictures. TIA
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-29-2004, 03:20 PM
Doug, I'll do that. I'll take some tomorrow and post them.
Steve F
69 911
71 911
87 Carrera
Old 01-29-2004, 08:37 PM
Cool
not for nothing; but,
I'd love to read what Jim Sims says about this ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-29-2004, 08:41 PM
This is the first time I've attached a pic. Hope it works. Here are the two pieces of the shaft after I removed it from the housing. I can't tell where the break originated. As you said Chris, good job it happened now.
Steve F
69 911
71 911
87 Carrera
Old 01-30-2004, 05:54 PM
No Expert
jgparker's Avatar
Wow, that picture is incredible. I didn't think they could break that way. Let me know if you need a core to regrind.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 01-30-2004, 06:08 PM
Banned
snowman's Avatar
SUPERGLUE
Old 01-30-2004, 06:33 PM
Snowman.......thick or thin ?...superglue that is.
Steve F
69 911
71 911
87 Carrera
Old 01-31-2004, 03:19 PM
Ho Hum 74's Avatar
Looks like the shaft might have had a crack on the right side of the left shaft in the pic (unless that's the start of the threads). Strange that the two halves are flat. Most shafts that fail in torsion fail at about a 45 degree angle to the length of the shaft.Sorry to hear about that.
Tristan
Old 02-01-2004, 11:28 AM
maybe the cam was dropped on the ground that set up a stress riser ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-01-2004, 11:32 AM
Super Moderator
cstreit's Avatar
Yep Tristan I agree, looks like a crack started on that upper right
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-01-2004, 04:18 PM
Senior Member
Thanks for the image, Steve!
Old 02-01-2004, 08:37 PM
Somewhere in the Midwest
MotoSook's Avatar
There it is....where it started.
It is "tensional" failure (perhaps the the technical term I should use, but it's late and it's been years since I was in a lab)...the surface is not unlike what I have seen when I have performed such failure in the lab.
Old 02-01-2004, 09:13 PM
Souk, I assume you are refering to the little tear on the r.h.s. I figured something was happening there.
Steve F
69 911
71 911
87 Carrera
Old 02-02-2004, 04:52 AM
MotoSook's Avatar
Well, nothing is conclusive until I have the part in hand (and then maybe), but my first analysis seems to be backwards. The fracture ("stress fracture") likely started in the 6-7 o'clock position in the picture I editied. The area I circled is the final fracture area (shear lip). The two features in the middle look suspiciously like a couple of inclusions that would have added to the weakening of the part. The 6-7 O'clock position (area) looks like there may be radial marks that would indicate it started there. But the crack didn't start in the middle or there would be some coning/cupping effect.
Were the camshafts cased then machined? Or were they forged..did they forge them back then?
If the casting had an inclusing that was machining into, it is likely that this part was destined to fail at that spot. The crack doesn't look a fatigue failure, so that part was probably bummed from the start. It just failed....
You ARE luck it happened during assembly.
Old 02-02-2004, 07:49 AM
I'm not aware of the history of the part. It came out of the same motor originally. It was a runner and there didn't appear to be anything amiss with the shaft. If you are interested this part is no good to me. I could get the boss cut off the shaft and send you the 2 bits.
Steve F
69 911
71 911
87 Carrera
Old 02-02-2004, 07:10 PM
MotoSook's Avatar
Steve, I wish I had time to play with such things, but thank you for offering.
I'm sure it wasn't anything you did to cause it to fail, so my best guess is that it was just its time....
Old 02-02-2004, 07:35 PM
