Aluminum Case?
I wanted to verify that my case is the aluminium one before I plan the rebuild:
Type: 901/05 SN: 909549 I believe this is alu case used in the 911E, am I right? Thanks
Donnie Currently Porsche-less.....
up-fixing der car(ma)
Isnt that 67? Whatever, 66/67, same deal, it's an aluminum case.
Warren Hall Student
For what it's worth E motors didn't come along until 1969 when Porsche was using magnesium so technically speaking Porsche never made an aluminum cased E motor.
The interesting thing about you case is that the serial no. is from a 67' 911 because 67' coupe motors started at 909001 and go up but the Red Book shows that 67' coupes (excluding the S) came with motor type 901/06 which was the same motor basically as the 66' 901/05 motor except that the cams had decreased overlap for the valves. So my guess is that the early 67' coupes came with motor type 901/05 like yours before being changed during the production run. Well I guess we may have found a new data point for the Red Book.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 11-25-2004 at 01:27 AM.. |
Thanks for the info, the serial number seemed strange to me too.
