Jkaser's Avatar
rebuild late chain wheel idler arms?
Are there bushings available to rebuild the late style chain wheel idler arms? I'm putting in the Carrera tensioners and have found several used idlers available for the upgrade. Always looking to save a few bucks! Thanks for the input. JK
Old 02-25-2004, 08:37 PM
Slumlord
Porsche_monkey's Avatar
I just went through this. Why risk your engine with an inferior idler arm? Obviously you could bore them out and instal a metric (16mm ID?) bushing but:
a) you will have trouble aligning the bore with the sprocket bore
b) you should probably also sleeve the spacer and add rigidity
c) the new ones aren't that expensive
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 02-26-2004, 05:57 AM
Jkaser's Avatar
PBH-- points well taken. Thanks, JK
Old 02-26-2004, 11:52 AM
Please explain. A replacement bushing is round; so is the idler arm bushing bore. Not sure what alignment you refer to.
The late idler arms don't use a spacer.
Sherwood
Old 02-26-2004, 06:23 PM
Author of "101 Projects"
Wayne 962's Avatar
This is something that you would need to do at a machine shop. The two holes would need to be indexed to each other. I'm sure it can be done, and I doubt it would hurt. Just use the proper tools to do it...
-Wayne
Old 02-26-2004, 08:29 PM
Slumlord
I think I am confused by the terminology. I assumed by 'late' he meant older style, since they have no bushing. If he means the newer style then they are already bushed and you only need to press the bushing out and press the new one in. No problem. To bush the older style (with spacer) you need to align the pivot shaft perfectly with the idler sprocket shaft, not easy.
84 Cab - sold!
Old 02-27-2004, 05:45 AM
