-   -   Gapping Aftermarket Rings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/150575-gapping-aftermarket-rings.html)
Tim Walsh 02-26-2004 07:05 AM
I hope to be putting my new JE pistons on my new motor this weekend if everything goes well but I'm a little worried about gapping the rings. How difficult/finicky is this and how did you take some material off the rings to create the right end gap?
84mm JE's in biral cylinders
Doug Zielke 02-26-2004 08:08 AM
Many D-I-Y'ers would just use a small mill file.
But because I do quite a few m/c engines needing rings, I bought a dedicated ring grinder....
http://forums.pelicanparts.com/uploa...1077811535.jpg
It has a little vise with a grinding wheel. You just crank it up. Does a nice job. Made in Sweden by Tebst, found at a local auto parts store.
magic930 02-26-2004 06:22 PM
What is the process for measuring a ring gap?
Tim Walsh 02-26-2004 07:16 PM
what you do put the ring in the cylinder that it's meant to go in straighten it with the piston and measure the gap with a feeler guage. take some material off the end, repeat until proper gap is obtained.
At least this is how I interperted it
