WTB-need asap- 2.4lt case
Subject says it all, need "GOOD" used 2.4lt case, no basket cases (pun intended!) please call Jack @ 417-235-7182 or 417-737-1482.
I have a 2.4 case. It came out of a 73E. It is perfect except one stud is pulled, along with the threads. This happened when a friend went to remove the studs to use on another engine. Only 1 stud was removed. The case would need a case saver.
edbogue@yahoo.com |
thanks for the help, also ne1 with an extra 3lt oil pump?
| All times are GMT -8. The time now is 01:20 PM. |
