2.4 valves hit?
I have a 1973 T bottom end with Schmidt 84.97mm pistons and cylinders and 73 E heads and cams installed. All 6 exhaust valves hit the pistons exactly at the small releif cut. The cam timing is at 2.7mm. No known work ever done to the bottom end. Any thoughts on the obvious?
Old 03-04-2004, 06:51 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
you can't clear E cams with T pistons or S cams with E pistons etc. shaved heads will do it as well along with a few other things. hmm.. what cams are you running and what pistons? Was this motor running or are you just now building it?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-04-2004, 06:58 PM
Sorry for the size on the pistons. The are the cast iron Schmidt 83.97 original T Cylinders /pistons and the cams are the 73 E cams.
Old 03-04-2004, 07:04 PM
Tim Walsh's Avatar
AHH that would do it. You can't clear E cams with T pistons. A machine shop can deepen the valve pockets for you for not a whole lot of money (well under 200)
Tim
1973 911T
2005 VW GTI
Old 03-04-2004, 07:05 PM
This was put together by some other person to replace a stock 73 T engine that had blown up. I thought the valves would hit, however I was told by this person that you could put any combination of 2.4 T E and S parts together . So E cams will hit T heads and S to E etc?
Old 03-04-2004, 07:11 PM
Tim Walsh's Avatar
Yes they will hit if timed properly. You CAN get away with timing them in some unusual way that they won't hit but your powerband will be way off. That's just what I've heard though. The official line and my experience is you can't run T pistons and E cams.
Tim
1973 911T
2005 VW GTI
Old 03-04-2004, 07:17 PM
2.4 pistons
Last summer I built a nice running motor with 2.2E piston with S cams, using E cams will also work but if your building the motor you have to improve the 7.5:1 compression of those 2.4 T pistons
Old 03-07-2004, 09:10 PM
