JE Pistons and GE Cams
Hi,
Anyone have any experience with the JE 10.5:1 pistons and GE60 or "S" cams. Do the standard pistons have a deep enough pocket, do they need machining or are they special order? Do GE40 cams work with these off the shelf pistons? Cheers Mark...... |
Author of "101 Projects"
I don't have my JE spec sheets in front of me, but I'll need a little more info on the pistons? (like bore?).
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
3.0 95mm 10:5.1 CR
Thanks Wayne........this is the last information before I order! |
I can't seem to find that info here (I'm at home) - I would suggest a call to JE. I know that they have several different types of piston domes, but I don't know off the top of my head what they are for these pistons... -Wayne
No Expert
I'm running the "off the shelf" 9.5:1 J&Es with Early S-Cams, and the piston to valve clearance is huge. 2.5mm intake and 4.0mm exhaust, if I remember right. The standard valve pockets are obviously cut for very agressive cams. I'm sure the 10.5:1 is the same or deeper.
Good luck. JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
GAFB
Ditto - my 10.5:1 JEs have huge relief- they had aftermarket hot cams in mind when they designed the dome profile. GE60s are not super-hot cams compared to the full range of cam options, I think you will clear no problem. Just an opinion though, I understand your desire to get more specific assurance...
Several BMWs |
