-   -   electrical connectors (http://forums.pelicanparts.com/911-engine-rebuilding-forum/151319-electrical-connectors.html)
markwemple 03-01-2004 04:07 PM
Doing a topend on an SC. The previous owner managed to break a couple of the clip style plactic connectors and held them together with bread ties. I now need to locate a source for them. I would hate to have to replace the whole engine harness for this. Any suggestions?
tgarnoldo 03-01-2004 04:47 PM
Look close on the connector and see if you can find the manufacturer's name molded into the connector. Then just search the web...
Good luck,
Arnie
magic930 03-01-2004 06:48 PM
These are probably Bosch type connectors, same as on most Bosche style fuel injectors and available at most auto parts stores.
tgarnoldo 03-01-2004 06:56 PM
I would check AMP. I think they make most of the connectors for bosch.
Thanks,
Arnie
Wayne 962 03-02-2004 12:15 PM
Very common - you should have no problem at most auto parts stores...
-Wayne
markwemple 03-02-2004 01:30 PM
Thanks Wayne and everyone. Do you think that there will be a choice of colors?
