-   -   alusil or nicasil (http://forums.pelicanparts.com/911-engine-rebuilding-forum/152133-alusil-nicasil.html)
markwemple 03-06-2004 06:29 PM
alusil or nicasil
Pulled my heads off and now I am trying to figure out what I have alusil or nicasil. For my 3.0 I know it could come with either but I don't see any marks indicating which. How can I tell.
Alan Cottrill 03-06-2004 06:33 PM
go get a magnet off of you refrigerator and see if it sticks to the cylinder wall. if it does it's nikasil if it don't it's alusil.
markwemple 03-06-2004 06:43 PM
I guess I am SOL. The magnet didn't stick.
Rondinone 03-06-2004 06:59 PM
I wouldn't cry yet. We in the "re-ring alusils" thread have copied a procedure for refinishing the cylinder wall at home for not much money. Read the thread and PM me if you have questions.
Grady Clay 03-06-2004 07:12 PM
Mark,
Today I got an e-mail from a Pelican about his cylinder leak test yesterday. This is a ‘72T that we built as a 2.8S with Nikasil 92 mm RSR P&Cs in 1974.
Here are yesterdays measurements:
#1 - 3.5 %
#6 - 2.0 %
#2 - 4.0 %
#4 - 2.0 %
#3 - 4.5 %
#5 - 4.0 %
Nikasils are amazing!
I expect the numbers will be all 2% or so when measured just off the track in a few weeks and not just street driving this past fall.
Nuff said!
BTW, the head nuts all took torque (but turned a little) and the case hasn’t been split since ’74.
Best,
Grady
rick conrath 03-06-2004 08:14 PM
You can have your Alusil cylinders re-coated with Nikasil. There is a "camp" that prefers the Alusil over the Nikasil. Check the threads.
Rick
'78 930
Rondinone 03-07-2004 06:32 AM
It's not a preference of alusil, it's a preference of money. Not everybody is keen to adding 3k to an engine rebuild.
But now that you mention it, why doesn't any current engine manufacturer use nikasil?
Doug Zielke 03-07-2004 07:38 AM
Too expensive?
But many current m/c and p/w motors have Nikasil bores.
And what about light aircraft?
blue72s 03-07-2004 10:06 AM
Biral
My cylinders are Biral.. Can they too be coated with Nikasil?
Superman 03-08-2004 12:07 PM
I checked my oil this morning for the first time in several weeks. It was about a quart low. In about 3000 miles. Most of that quart leaked out between the right side chain housing and the cam housing. In other words, I'm not sure my engine is even burning the air-cooled "minimum" amount of oil. All evidence, including the butt dyno, suggest these ring are air tight. They were replaced at 182K miles, about 50K miles ago. The Alusil cylinders were simply reused. So to those who think their new Nikasils work better than my old Alusils, I say "Bring it on." I'll bet my leakdown numbers are similar to those posted above.
markwemple 03-08-2004 02:52 PM
Did you replace the rings because you had to or though it was a good idea?
Tim Walsh 03-08-2004 03:45 PM
Birals are very different. They're cast iron cylinders with Al. fins. They function exactly the same as Chevy cylinders. Nikasil and Alusil are Al with a special coating on them for wear.
Rondinone 03-08-2004 04:03 PM
That's great superman. So far, in the first 300 miles since my rebuild, the engine has burned 8 oz of oil. It had 115k miles, the rings were replaced because the valve guides were shot and I decided to rebuild the whole engine. Comp before teardown was between 150 and 155 for all cylinders.
Yeah, I know they're junk. Send me your old ones.
blue72s 03-08-2004 04:38 PM
Yes but what I asked is, can the cast iron walls be lined with Nikasil? (which is only a thin lining)
Tim Walsh 03-08-2004 05:06 PM
AHH.. that I don't know I guess the real question is how thin can you make the Al cylinders before you run into problems and then how thick is the Al exterior of the Biral cylinders.
I'm not sure why you want to coat the iron part of the cylinder since it makes a good wear surface.
Just some musings by an amatuer
fly944 03-08-2004 05:30 PM
Carrera Gt
Just read the other day that the Carrera Gt is using Nikasil Cylinders in the V10. Not sure of the exact specifics.
cnavarro 03-08-2004 06:50 PM
You can nikasil cast iron. Done it before for rare or NLA cylinders for vintage guys. Reduces friction (= free horsepower) and gives you a much better wear surface. Nascar guys use nikasil on their iron blocks for that reason.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
blue72s 03-08-2004 08:28 PM
I'm pleased to hear that.
The disadvantage of the Mahle-Nikasil ones is that, due to lack of steel, they have different expanding properties hence the need of dreaded dilavar studs to match. So "modified" Mahle-Birals, IMHO, would be a better solution as steel studs can still be used on them. Of course this type of mod can only be done on 2.4 or lower.
Right?
BTW, how thick is the cast iron wall of the Mahle-Biral? And how thick of nikasil lining would be rquired? (what was the lining thickness of the 2.7?)
The 2.2 & 2.4 Mahle replacements of today which are nikasil, are they of the exact same construction as the original 2.7?
Sorry for so many questions..
tahnks
cnavarro 03-09-2004 05:25 AM
The nikasil plating can be as little at .004" on diameter or in excess of .015" on diameter. For example, i've taken a stock bore 356 cylinder that was wiped out from a grenaded piston and have been able to overbore and replate to factory size, better than new.
Nickies cylinders in bore sizes from 84-86+ for the 2.2/2.4 and 89-92+ are fully finned and have provisions for oe sealing rings. Nickies in bore sizes 95-98+ are also fully finned, based on 3.0 KS alusils / 3.2 Mahles, not the half-finned turbo cylinders and do not use the sealing ring, per the design on the 3.2 mahle. Rather there is a taper on the sealing surface that causes a gradient in clamping loads, thus forming a carbon seal at breaking. Custom piston combinations with Nickies will be courtesy of Pelican Parts and will be available in kit form through the rebuild wizard hopefully sometime in the near future. Call Eugene for more details.
For those who don't know what we're talking about:
Fin shot of mahle vs. Nickies
http://www.lnengineering.com/gallery...s/100_0257.JPG
Photos of a 92mm Nickies cylinder for 2.8 911:
http://www.lnengineering.com/gallery/Porsche%20911%202.2%202.4%202.7%202.8%20Nickies/Final%20Production%20Demo/index.html
Charles Navarro
LN Engineering
markwemple 03-09-2004 06:31 AM
How much does this run? ($)
