-   -   cam housing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/152134-cam-housing.html)
markwemple 03-06-2004 06:30 PM
cam housing
I have wayne's book but it doesn't cover dealing with the different type of cam nt/assembly I have (3.0). I have the nut off but am having difficulty getting the gasket? undrneath off so I can remove the housing.
ChrisBennet 03-07-2004 04:47 AM
Are you asking about the round plate with 3 holes in it behind the sprocket? That plate is held in there by a large O-ring. They'll pop out with a little careful pulling in the screw holes. I think you can use the cam to pop it out also.
-Chris
EDIT: Check out this thread
markwemple 03-07-2004 03:00 PM
There is a key on the cam holing the thing together and I don't want to break anything. Nothing I have read shows this or talks about how to deeal with it.
ChrisBennet 03-07-2004 03:48 PM
The woodruff key must be removed first. I put a rag in the left chainbox or tip the motor such that if I drop the key it doesn't fall into the motor.
-Chris
Wayne 962 03-07-2004 09:27 PM
Sure do cover this, check the book again. I don't really quite understand your question though...
-Wayne
markwemple 03-08-2004 06:38 AM
Wayne, it is a woodruff key. I never saw it mentioned but, I hope to get it out. Believe it or not, it diasassembeled that entire side with the cam still in the box.
dtw 03-08-2004 07:18 AM
You are having trouble with the woodruff key? Just stick a small screwdriver against it and tap it out with a hammer...
markwemple 03-08-2004 08:42 PM
Where do you put the screwdriver (flathead I am supposing)?
cstreit 03-08-2004 09:03 PM
RIght up against where the key sticks out of the cam. Make SURE that you put a rag near the chain area so it doesn't go into the motor!
