-   -   getting rockers off (http://forums.pelicanparts.com/911-engine-rebuilding-forum/152257-getting-rockers-off.html)
markwemple 03-07-2004 03:02 PM
getting rockers off
I am having a heck of a time getting the rockers off. The 5mm is twisting my wrench and yes I am truning it the right way, lefty loosy. Anyway any suggestions!
Rondinone 03-07-2004 04:41 PM
I took a standard allen wrench for the inside bolt (5mm), and put a box end wrench on it. It flexed considerably, but they all came loose. Also, soak them in pb blaster overnight.
john walker's workshop 03-07-2004 05:05 PM
a 5mm, 1/4" drive socket may be of harder material than a simple allen wrench. a good german one like hazet.
markwemple 03-08-2004 06:43 AM
Soaked them overnight and gave the wrench a good whack with a hammer. WORKED!! Man did porsche over tighten them? I hope they don't have to go on that tight.
Doug Zielke 03-08-2004 08:01 AM
The cone and screw is exposed to the outside, and can get rusty.
When you whacked the screw, you helped break up the rust.
As far as tightening them goes....go to the Competition Engineering website, and read the tech tip Walt Watson has there. He knows his stuff!
