-   -   '79 SC Euro rev limiter? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/152714-79-sc-euro-rev-limiter.html)
Pettybird 03-09-2004 07:45 PM
Does it exist? What is the rev limiter supposed to be set at? Wondering if it's broken, bypassed or not installed. Tach can't be off by that much...
Doug
john walker's workshop 03-09-2004 07:55 PM
on US cars, it's attached vertically to the inside of the cowl, by the hood hinge. you can see and reach it if you pull the fuel gauge. black plastic, about 3x3x1, white multi wire plug at the bottom, and a X type moulding on it's face.
Pettybird 03-09-2004 08:00 PM
Thanks John
Does that mean I don't have one? If you unplug it, will the car still work, or would you have to bypass it somehow? I'm a couple days from looking at the car...
doug
fintstone 03-09-2004 08:08 PM
My car doesn't have one either.
john walker's workshop 03-10-2004 08:00 AM
it will still run if it's unplugged.
Ho Hum 74 03-14-2004 05:25 AM
Folks,
Doesn't the rotor have a limiter built in?
Tristan
fintstone 03-14-2004 11:42 AM
Your '74 would. Later cars don't.
aigel 03-15-2004 03:34 PM
Just get a shift light. That way you won't have the limiter come on on you in a 90mph turn! :)
George
