Old Member
To Paint or Not to Paint
To paint or not to paint?
What are the pro's and con's regarding the painting of aluminum and magnesium cases and other components during a rebuild of the early 2.0 - 2.7 engines?
I need some feedback from the experts about this issue.
Air-cooled aircraft engines of similar design and horsepower come painted from the factory and are completely painted at rebuild as a way to prevent corrosion. Hardware is often cad plated to prevent rust of steel parts.
Clifton Brown
https://www.mancalamarketing.com
Old 03-10-2004, 10:07 AM
Friend of Warren
The consensus on this board is it is never a good idea to paint your cases, regardless of material. Just holds in the heat.
Kurt V
Old 03-10-2004, 11:01 AM
Exactly. Heat, then weight is the issue. The cad plating, however is a great idea! I would think that for aircraft, heat is less of an issue (cooler at altitude plus that prop is a little bigger than our 11 blade fan. I guess they paint to prevent corrosion?
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 03-10-2004, 01:28 PM
126coupe's Avatar
Just clean the sucker until you can eat off it
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-10-2004, 02:43 PM
Old Member
Thanks for all the feedback. I checked older posts concerning the issue and everybody seems of a like mind.
It's just hard to get a magnesium case to shine like new once it's oxidized.
Clifton Brown
Old 03-10-2004, 05:13 PM
...is my Daughter
Avery's Avatar
Oh come on....a coat of paint does not weigh THAT much. After hours of cleaning up these mag cases, it's just so dissatisfying to see how poorly the cases still look. So...I've painted a case with no ill effects (read no overheating) just to check it out. And it looked great and it never peeled. The paint was from Eastwood.
Here's an unpainted case.
Here's a picture of the painted case. I think it looks nice.
Felmir
Keep Going!
Felmir Singson RGruppe #479
"Living the rest of my life, one minute at a time"
Old 03-11-2004, 10:21 PM
Old Member
Thanks for the picture. It's truly worth a thousand words. The case looks great, what color paint from Eastwood?
Clifton Brown
Old 03-11-2004, 10:31 PM
...is my Daughter
Avery's Avatar
The paint is Eastwood "Detail Gray".
Keep Going!
Old 03-12-2004, 07:52 AM
Old Member
There is a benefit if you consider preventing corrosion an issue.
Anyone living close to the ocean with their car parked outside is going to be at risk unless their engine is covered with oil or paint. The salt spary is airborne and travels inland a significant distance when the wind blows onshore.
Any uprotected metal is subject to corrosion or rust (oxidization) unless protected. That's why aircraft engine manufacturers paint their magnesium and aluminum engines, nobody ever sees them either.
Clifton Brown
Old 03-12-2004, 09:24 AM
A Quiet Boom's Avatar
What about a coating as opposed to paint? I'm pretty sure there are thermal radiant coatings out there. I've seen thermal barriers used on exhaust and I've personally used oil release coatings inside engine blocks to aid drain back to the sump. There are even anti friction coatings for pistons and the like. Seems to me a thermal transfer or radiant coating would help cooling as well as possibly look good and prevent corrosion.
Thermal dispersants can be found here. http://www.skperformance.com/ceramic-finishes.htm
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 03-12-2004, 03:52 PM
Old Member
Christian
Thanks for the link to SK Performance. I sent them an email asking for help selecting an appropriate product for a Porsche engine case to prevent corrosion and transfer heat. I'll let you know what they advise.
Clifton Brown
Old 03-12-2004, 04:47 PM
abit off center
cgarr's Avatar
Corrosion is a big problem on aircraft especially on the magnesium parts. I used Goodson Last Blast paint on my 69 912 902/16 magnesium 5 speed because of the pitting that had started after 35 years. Regarding "cooler at altitude" it is colder but the air is also a lot thinner and much less able to pull the heat away from the cylinders, thats why your oil temp always rises with altitude as the air temp drops, hmmmm funny thing aint it? Oh, and that big propeller is only there to keep the pilot cool!!!!! just watch how fast they start sweating once its stops.
Craig
______________________
Craig
G2Performance
Old 03-13-2004, 06:26 PM
