Assembly begins
Starting Friday evening with the rods, torque and undo the ARP rod bolts 3 times at 35lbs...
http://forums.pelicanparts.com/uploa...1079305660.jpg By Saturday afternoon the case is together with only a few moments of panic... http://forums.pelicanparts.com/uploa...1079305743.jpg By Sunday afternoon the head studs are in and the flywheel is torqued down. http://forums.pelicanparts.com/uploa...1079305821.jpg |
Very nice. You're further than me. I've only just completed the crank.
One thing though: my ARP guide says 45 lb/ft torque on the rod bolts. Did your guide say 35?? Tristan |
My ARP instructions for the rod bolts part 204-6005, Porsche 930 turbo. Clearly says 35lbs 3 times... (loosen tighten etc.)... if not using the stretch gauge method.
Mine are going into a 2.7 RS spec engine and are part # 204-6001 which probably explains the difference. Says, "Application Porsche 10mm)
The 87 930 has 9 mm rod bolts which should be torqued to 35 ft/lbs while using the ARP assembly lube. I did mine 5 times just to make sure. The torque and retorque is to eliminate any new (abnormal) tread to nut friction.
Hmmm.... a 2.7 has 10mm and a 930 has 9mm? Interesting
| All times are GMT -8. The time now is 01:44 AM. |
