Ho Hum 74's Avatar
Sealing the case halves: where does the sealant go?
In Wayne's book he indicates putting the orange goop one the mating surfaces surrounding the case through bolts. Others have indicated this is not necessary. I'm concerned about getting goop on the bearing surfaces when the case halves go together.
What' the right answer? I'm thinking about putting it on but stopping short of the main crank bearings.
Tristan
Old 03-20-2004, 05:23 AM
Senior Member
Doug Zielke's Avatar
Any excess is dissolved and washed away by the engine oil.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-20-2004, 07:15 AM
this why the 574 needs to be applied carefully and deliberately. Yes some will ooze (engineering term) out on both sides of the mating surfaces, but like Doug said, the rest will disolve in the oil...
Old 03-20-2004, 11:00 AM
Author of "101 Projects"
Wayne 962's Avatar
Right - the theory on putting it on the inside is that the sealant will be slightly thick. You don't want the case bowed when you bolt it together because there's no gasket material in the center. This is standard procedure for mounting and sealing just about anything, whether it's a 911 engine or a unit on a satellite.
That's the theory - in reality the thickness of the 574 layer is probably inconsequential.
-Wayne
Old 03-20-2004, 11:58 AM
