-   -   964 cam in 81 US 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/153663-964-cam-81-us-3-0-a.html)
aigel 03-15-2004 03:33 PM
I am playing with the idea of putting 964 cams in place of the SC cams. Actually welding and regrinding my cams to 964 profile.
1. Will I have any valve to piston clearance problems with the stock 81 US pistons (CR: 9.3:1)?
2. Will I be fine with the stock SC valve springs using the 964 cam?
I have no time to take the heads off or do anything else that 's more involved. Please let me know if I can do this without valve to piston clearance problems, before I haul the bumpsticks off to the cam grinder! :)
Thanks!
George
dd74 03-16-2004 11:06 AM
I think Jim (Superman) did the same mod as what you're thinking of. He used 20/21s, which are a bit more radical than 964 cams. If memory serves me, he has a stock valvetrain, so if 20/21s will be fine, 964s should work, too.
911 valvetrains are fairly substantial. They can withstand 7,000 + RPMs. You won't rev that high with your engine unless you miss a shift.
...so don't miss a shift. :)
mtelliott 03-17-2004 07:52 AM
You might want to get your rockers reconditioned (or new ones). That's what was suggested to me when I was thinking about it. I didn't end up doing it because I wasn't sure what it would do to emissions. I heard conflicting advice so I went conservative.
oneblueyedog 03-17-2004 09:07 PM
I got new rockers after my regrinds. I've always heard it was essential since the cam and rockers must bed together on their hardend surfaces. Worn rockers have less of a hardend surface since they are already worn to the old cam profile.
Lee 78sc
Elgin 330 cis cams (cheater cam)
New Stock Mahle cis pistons 8.5:1
Boat tailed webs.
Much more fun to drive now.
aigel 03-17-2004 09:12 PM
I'll get new ones. I learned that you would want new bushings too, if you have them refurbished. The cost will be similar to just getting new ones.
EBS says I should have no clearance problems with the 964 cam. Of course I will check, but want to make sure that I am 99% confident. Would shuck to have the 964 grind ground down again to the SC for clearance reasons. :)
Thanks, George
Tinker 03-17-2004 10:20 PM
You need to reset that value spring sims to get the correct valve spring height for the cams. Otherwise you risk coil bind if you ever miss a shift or slightly over rev the motor.
Tinker
aigel 03-17-2004 10:23 PM
Uh-oh, now it is getting interesting. I am not prepared for that. Better go check out the lift difference betwen the 964 and the SC cam. Thanks for the pointer!
George
aigel 03-20-2004 09:26 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/96467-3-0-cis-cam-grinds-964-vs-web-20-21-a.html
According to this thread I am looking at about 200 and 600 micron of lift difference on the intake and exhaust side between the SC and the 964 grind. I doubt that this will present a problem. What do you guys think?
George
