ischmitz's Avatar
Send a message via Skype™ to ischmitz
Oil pressure relieve valve - questions
I want to change the oil pressure relieve valve spring and the oil pressure safety valve spring and the pistons. I am wondering how much oil will come out of there if I take them apart without draining the oil first. A little bit, a couple of quarts or all? Has anyone done this before without draining the oil?
How tough is it to get the pistons out of there. Will a magnet work?
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-20-2004, 09:41 PM
Bird. It's the word...
Fishcop's Avatar
Both those caps are very low on the engine. I imagine it would be just like undoing the sump plug! If it's new(ish) oil I'd drain the oil into a clean 98c bucket and return the oil when you're finished.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-21-2004, 01:00 AM
One mine not much more than a quart. Also depends on how fast you work. A magnet worked for me to get the piston out.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 03-21-2004, 03:52 AM
ischmitz's Avatar
I figured the oil pressure relieve valve dumps into the gravity feed line. Wouldn't that dump the entire tank once I take the piston out?
Anyway, I have to change the oil pretty soon. So I just hold off on it.
Ingo
Old 03-21-2004, 06:24 PM
