bosch ditributor
hello ,
what is the difference between a 2.0E bosch distributor and 2.2S (the RPM only?) ... can I use mine ((a 2.0E) without any problem or my engine will not run well ? thanks :) |
Thor-
I believe that the only difference is the rotor (and the distributor part number). Get an S rotor and you should be good to go. -Scott |
the curve is not different ?
The curve is the same.
thanks a lot Scott:) :)
| All times are GMT -8. The time now is 06:15 PM. |
