hello ,
what is the difference between a 2.0E bosch distributor and 2.2S (the RPM only?) ... can I use mine ((a 2.0E) without any problem or my engine will not run well ? thanks
Stressed Member
Thor-
I believe that the only difference is the rotor (and the distributor part number). Get an S rotor and you should be good to go. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
the curve is not different ?
Stressed Member
The curve is the same.
thanks a lot Scott
