911L oil pressure
If I needed to know the correct color of the fuse box cover on my 956, I'll bet you guys would be all over that! Thanks
Old 03-24-2004, 05:18 AM
konish's Avatar
I wish I had my bunny with a pancake on his head....
Old 03-24-2004, 05:40 AM
Senior Member
Zendalar's Avatar
error: unable to get the funny...??
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 03-24-2004, 06:06 AM
Ho Hum 74's Avatar
Didn't he ask a question about what was a healthy oil pressure for his 911. Did he get flamed because it was deemed to be too pedestrian for this board?
Tristan
Old 03-24-2004, 07:28 AM
Ho Hum 74's Avatar
PS. R356t - don't get offended keep trying, there are some good folks on this board.
Tristan
Old 03-24-2004, 07:29 AM
No Expert
jgparker's Avatar
Wow, did the origianl question and all the replies change on this? I think it's 10psi per 1K RPM. We do try to be helpful generally.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 03-24-2004, 09:24 AM
Ho Hum 74's Avatar
JP,
I was looking at your rebuild site, that's almost the same engine as mine except mine is 2.7 adn MFI. Am I reading things right, did you break a head stud AFTER you put it all together? Sorry to hear that if you did.
Tristan
Old 03-24-2004, 12:39 PM
No Expert
jgparker's Avatar
Tristan,
Yup, I broke a head-stud 300 miles into my 2.8 engine break-in. I had reused the Dilivar studs from the previous rebuild, since they look perfect, but this was obviously a big mistake. I've installed steel 993 studs now.
Thanks,
JP
Old 03-24-2004, 02:44 PM
Ho Hum 74's Avatar
JP,
I was looking at that and thinking that your studs look identical to mine with the black epoxy coating. Well, you said yours were Dilavar - how did you know that? I thought mine may be Dilavar too but a magnet sticks to them. I'm thinking about just leaving them in the case and re-using them because I think they're the steel ones.
Sorry about hijacking this thread - we can take this off line via e-mail if you want. twhitehead@deloitte.com
Tristan
Old 03-24-2004, 03:07 PM
No Expert
jgparker's Avatar
Tristan,
My old studs failed the magnet test, so I'm sure they are Dilivar. It's funny, in Wayne's book, he shows an uncoated Dilivar Stud and a epoxy coated steel stud. My Dilivar studs were epoxy coated and my new 993 steel studs were uncoated steel. Go figure. Sorry about getting OT r356t.
JP
Old 03-24-2004, 03:35 PM
A Quiet Boom's Avatar
Good luck,
JP
That is the rule of thumb for ALL high performance engines, I've read a lot of books and talked with many engine builders and they all agree on the 10psi per 1k rpm. It's important to note however where the pressure is being read since engines are an "open" hydraulic system the idea measurement point is in the gallery between the pump output and the main bearings. Since I've never really looked closely at a 911 oiling system I'm not certain if that's possible but I do know I get higher readings if my sender is located in the position near the bellhousing as opposed to the location in the cam line.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 03-24-2004, 03:59 PM
Look, I'm trying to do some work here. I keep getting interupted (E mail alarm) Because you 2 don't have a life and are trying to hide that fact from everyone else by using my thread.
Old 03-24-2004, 04:12 PM
Sorry! I won't help next time! You could turn off email notification BTW....
Old 03-24-2004, 04:32 PM
No Expert
jgparker's Avatar
Look, I'm trying to do some work here. I keep getting interupted (E mail alarm) Because you 2 don't have a life ...
Duly noted, I'll keep the chatter down in the future. I did my best to answer your question though. So much for the '68 911L owners club... Woops, did I make that email ararm go off again?
JP
Old 03-24-2004, 05:29 PM
Friend of Warren
Is this guy for real? If so, I hope your damn alarm went off again. Oh and I can guarantee you that I will never give a serious answer to any of your questions.
Kurt V
Old 03-24-2004, 06:38 PM
E mail alarm again...the way I see it, I as a novice P builder asks the questions, then sit silently and patiently waiting for the experts to answer. If there is no answer, then I figure I need to read my books a bit deeper as the answer may be there. Or...look for an original thread. Just my .02.
Dan
'68 911L w/RSR
Gruppe 'B' Bastard Factor 1856
Old 03-24-2004, 06:47 PM
Dan, do you have any pics of your car?
I assume "w/RSR" is body changes? I'd love to see what they look like.
1968 911L
2004 Dodge Dakota SLT Plus
Old 03-25-2004, 09:53 AM
Ho Hum 74's Avatar
Guys I think that was an attempt at humor. At least that's the way I'm taking it.
Old 03-25-2004, 10:54 AM
pics of RSR
Hi Dotorg,
Glad to oblige, got a great deal on it...see the thread on purchase cost of 911's...
Dan
'68 911L w/RSR
Old 03-25-2004, 07:32 PM
Additional upgrades will be full rollcage, upgraded to full race suspension, race fuel tank, upgraded disc brakes, convert from sportomatic to 5 speed manual, motor from 2.0 to 2.5 race/street.
Dan
'68 911L w/RSR
Old 03-25-2004, 07:35 PM
