-   -   Autopsy of 2.2S, Part Deux - #5 Rod (http://forums.pelicanparts.com/911-engine-rebuilding-forum/155834-autopsy-2-2s-part-deux-5-rod.html)
TimT 04-06-2004 05:46 PM
The last "refreshing" I did on my 2.2 was in 1999
I did the following to provide a "bullet proof bottom end"
*Oil bypass mods
*Installed piston squirters
*modified crank and center main bearing
*install 930 oil pump
Im just about to fire this same engine up in its latest iteration, twin plugged,with TWM TB's, crank fired w/ engine management
Since you have the case split, definaletly go for the oil bypass mod... get an updated oil pump ( carrera pumps can be had inexpensively), install the squirters...
the crank bearing mod is purely discretionary... if its a street car probably no need...on a track car its "insurance"
Also weld a baffle in your oil tank.... there was a recent thread about this mod also
