Stock deck height
When Porsche builds a stock engine -- let's say I'm talking about a 8.5:1 CR 3.0. What is the stock deck height? I know that when rebuilding you should check this measurement, and keep it to approximately 1mm (depending on who'se figures you're going off), but what is it typically from the factory.
Bump?
Is it usually around 1.5mm? I assume it depends on the engine, but there must be a stock standard or range which applies to most engines? |
| All times are GMT -8. The time now is 01:24 PM. |
