-   -   How to test Engine Oil Cooler Thermostat? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/156682-how-test-engine-oil-cooler-thermostat.html)
hobieboy 04-03-2004 12:10 PM
Hi,
Wayne's book said to put it on a hot plate & make sure it opens.
How could I tell if it did open?
Am I supposed to hear or see some moving parts? :confused:
I tried the method & the whole unit is so hot that I need the oven mitts but didn't notice any changes.
Thanks...
dtw 04-03-2004 01:48 PM
I test them by sticking it in a saucepan full of fresh oil. That way, I can hold a thermometer in the oil and see the temperature when the thermostat opens. Either way, you'll see the thermostat slide open when it heats up.
hobieboy 04-03-2004 07:08 PM
Thanks Dave...
Tried your suggested method & the thermostat does indeed slides. The triggering temp seems to be around 185F - does it sound right?
thanks.
oneblueyedog 04-05-2004 07:26 AM
I used water. I found mine to be bad. Yours sounds like it is good. It think the opening temp is stamped on the unit.
Mine did not open at all.
dtw 04-05-2004 08:39 AM
185F sounds spot-on.
hobieboy 04-05-2004 08:42 AM
Thanks guys...
Now that I have the peace of mind, its going back in with a new seal :)
