-   -   are 3.3 turbo rods the same as 3.2 rods? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/157005-3-3-turbo-rods-same-3-2-rods.html)
adomakin 04-05-2004 01:15 PM
I am about to buy a 3.2 crank for my 3.3 turbo, the guy will only sell the crank and rods complete. are the rods the same?
Andy, UK
beepbeep 04-05-2004 01:40 PM
PET shows no special rod number for 930/66/68 (turbo engine)m so it seems they are the same.
PET says 930 102 014 09 crank for 930/20/25/26 (Carrera) and 930 102 014 10 crank for 930/66/68.
As far as I know, those last two digits are mostly revision numbers.
Drive gear that goes on the crank is different as far as I can see.
adomakin 04-05-2004 01:58 PM
nice one beep, im buying it!
Andy, UK
beepbeep 04-05-2004 03:21 PM
Well don't take my word for granted...that's what I could check by peering into PET.
I know how you feel, you hear something is the same and you want to know for sure but no one is willing to bet on it. I did the same thing by bying Carrera shafts to use on SC with 930 gearbox. It was a shot in the dark, i only knew that Carrera had same CV diameter as 930 and same hubs as SC. It worked ;-)
beepbeep 04-05-2004 03:25 PM
This is for 1984. As you can see there are different weight classes for rods but no different rods for 930/Carrera:
http://project911.luminasweden.com/temp/rods.gif
beepbeep 04-05-2004 03:28 PM
And here are cranks for year 88:
http://project911.luminasweden.com/temp/crank.gif
beepbeep 04-05-2004 03:30 PM
Also, note that Wayne sells different cranks for Carrera and 911/911 Turbo:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_enginA_pg3.htm#item9
Do some more research. Cranks are probably the same but one of them might have some extra little locking pin for some dizzy ring gear that isn't the same for Carrera/930.
BURN-BROS 04-05-2004 04:42 PM
How about rod/main bearing part #s. Maybe a different number would indicate a larger fillet for the 3.3. I don't know but its worth a shot.
jgparker 04-05-2004 04:52 PM
I don't think you are supposed to admit that you have PET. Big brother is always watching...
I wish Porsche would sell it, or make a version available. They stopped producing the paper parts and Microfilm version some time ago, so as far as I know, there are no new parts manuals available to the public anymore. I'm glad I get mine while they were still available (Paper that is).
JP
adomakin 04-05-2004 10:43 PM
cheers guys and thanks for the PET shots Beep! Wayne could you shed some light here?
beepbeep 04-06-2004 12:36 AM
Nope, all bearing shell #'s start with 930 and are the same for both Carrera and 930. There are oversize shells for machined cranks though...
As i said before, I'm more or less 100% sure that cranks are identical bore/stroke/bearing-wise. Only thing that differentiates them is "drive gear" numbers (nr. 10 in PET-shot).
It might be so that cranks are the same but are supplied with those "drive gear" rings...and depending on which crank you order, you get different gears. Prices are almost indentical too...
adomakin 04-06-2004 11:44 AM
cheers beepbeep, youve done me proud!
