Elombard's Avatar
Cam tower removal ?
I am buying a used motor that has cam tower leaks. I will probably use at is but I was curious what is involved. looks like the timing chains come off, rockers come out and then the towers come off. The heads and head studs can stay on. IS that right? Might be a bigger pain than it is worth?
TIA
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-08-2004, 02:53 PM
Elombard's Avatar
Never mind, I just looked in the rebuild book - way more than I want to tackle without going all of the way. Maybe its the rocker shafts or return tubes, have to look when it gets here.
Old 04-08-2004, 03:12 PM
