3.0 tensioner upgrade
To install the hydraulic timing chain tensioners in a 3.0 do you have to pull the engine?? It might make things a whole lot easier regardless.
I think most have installed with motor in place. I did, and had no trouble.
a partial engine drop may make things easier still. Lower the engine down and pull off the sheet metal.
| All times are GMT -8. The time now is 07:57 PM. |
