-   -   cam housing part number question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/159445-cam-housing-part-number-question.html)
adomakin 04-21-2004 07:46 AM
my cam housings have got the part number 964 105 111 0R
anyone know what are they from and are they ok for my 3.3 turbo?
Andy
adomakin 04-22-2004 09:14 AM
carmad 04-23-2004 12:49 PM
Camshaft housing for mine is 930 105 021 00 on my 80's 930. The 964 part designation means it is from the later 964 models.
ChrisBennet 04-24-2004 09:20 AM
I've seen the 964 casting number on a friends '88 911 cam carrier. The valve cover studs on the 964 cars ('89-94) are 6mm instead of 8mm i.e. the parts are different but they started with the same casting.
-Chris
adomakin 04-25-2004 01:37 AM
so have i got to use 964 cam covers on my 3.3 turbo? is that ok?
ChrisBennet 04-25-2004 05:35 AM
If you've got 964 cam carriers (6mm studs) you'd need to use 964 covers. If that is what you have it might be easier/cheaper to sell your 964 carriers and get 911/930 ones.
-Chris
adomakin 04-25-2004 09:36 AM
does it matter if i use the 964 cam covers ? i know the 930turbo covers are stronger but if i can find some good used 964 covers would they do?
ChrisBennet 04-25-2004 01:36 PM
They might leak (they do on 964's I'm told) and even used valve covers won't be cheap. The oil feed line for the 964's is different, I don't know if 964 top covers will clear the old oil lines. I think I tried this this years ago but I can't remember.
-Chris
adomakin 04-25-2004 11:17 PM
hmm. looks like im gonna have to get myself a set of 930 cam housings!
Cheers Chris
