Severe depression sets in...
Just got word from my mech that BOTH my S cams have bad lobes. He does not recommend buildup and regrind due to hardness issues? Anyway, I have not been able to locate any through searches of the classifieds - #'s should be 167 & 168 - if anyone knows of a source I would be most grateful.
Cams are early S setup for MFI (from a 2.2).
Kevin 1972 T Targa |
BS on the hardness issues. send them to webcam and they'll take care of you.
Kevin:
I'll "Second" John's suggestion,........ ![]() As long as the bearing surfaces are intact and perfect, Webcam can fix your cams as good as new. If you do this, just be sure to break them in EXACTLY as recommended by them. Start the engine and run it at 2000 RPM for 20 minutes; no idling during that critical time period.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve,
Is it the same procedure for breaking in new rocker arms? thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Stressed Member
Kevin-
A few months ago EBS had N.O.S. S cams for something like $325 each. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
Author of "101 Projects"
Any good Porsche mechanic knows that these can be reground and rehardened. He's confusing the cams with the crankshaft. Regrind/weld the cams and think about getting a new mechanic - sounds like he's not completely clued in.
Or better, send your engine to JWW... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
-Wayne
Elgin Cams south of San Francisco is another good place to get the cam shafts refurbished and reground. They can also change the profile while they're at it if you so desire. Jim
i see the theory behind new cams/new rockers to mate both parts nicely but what if you are using good used cams from a different engine?
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
If you use good used cams you need to have the used rockers (riding on the original lobes) If they aren,t available then the contact surface of the rockers should be fresh and you break them in again at startup . Cam breakin is at about 2000 rpm for about 20 minutes.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
can you just have the contact surfaces polished again? do they have to be hardened?
The rockers can be reconditioned by a machine shop .I presume they polish the surface and check or replace the bushings . This should be done to the existing rockers even if the original cams are repaired(Build up and regrind) unless rockers are removed and replaced on the lobes they were running on already.
cheers john
Andy
