KevinG's Avatar
Severe depression sets in...
Just got word from my mech that BOTH my S cams have bad lobes. He does not recommend buildup and regrind due to hardness issues? Anyway, I have not been able to locate any through searches of the classifieds - #'s should be 167 & 168 - if anyone knows of a source I would be most grateful.
Cams are early S setup for MFI (from a 2.2).
Kevin
1972 T Targa
Old 04-14-2004, 05:24 PM
BS on the hardness issues. send them to webcam and they'll take care of you.
206 637 4071
Old 04-14-2004, 06:33 PM
Kevin:
I'll "Second" John's suggestion,........
As long as the bearing surfaces are intact and perfect, Webcam can fix your cams as good as new.
If you do this, just be sure to break them in EXACTLY as recommended by them. Start the engine and run it at 2000 RPM for 20 minutes; no idling during that critical time period.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-14-2004, 08:04 PM
Steve,
Is it the same procedure for breaking in new rocker arms?
thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-15-2004, 07:13 AM
Stressed Member
Scott Clarke's Avatar
Kevin-
A few months ago EBS had N.O.S. S cams for something like $325 each.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 04-15-2004, 08:20 AM
Author of "101 Projects"
Wayne 962's Avatar
Any good Porsche mechanic knows that these can be reground and rehardened. He's confusing the cams with the crankshaft. Regrind/weld the cams and think about getting a new mechanic - sounds like he's not completely clued in.
Or better, send your engine to JWW...
-Wayne
Old 04-15-2004, 09:49 AM
Wayne 962's Avatar
Originally posted by PatrickT
Steve,
thanks...
Another note - if you regrind the cams you must use new rockers *or* have your old ones reground as well.
-Wayne
Old 04-15-2004, 09:50 AM
Elgin Cams south of San Francisco is another good place to get the cam shafts refurbished and reground. They can also change the profile while they're at it if you so desire. Jim
Old 04-16-2004, 05:54 AM
adomakin's Avatar
i see the theory behind new cams/new rockers to mate both parts nicely but what if you are using good used cams from a different engine?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 04-17-2004, 10:10 AM
If you use good used cams you need to have the used rockers (riding on the original lobes) If they aren,t available then the contact surface of the rockers should be fresh and you break them in again at startup . Cam breakin is at about 2000 rpm for about 20 minutes.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 04-25-2004, 06:27 PM
adomakin's Avatar
can you just have the contact surfaces polished again? do they have to be hardened?
Andy
Old 04-25-2004, 11:21 PM
The rockers can be reconditioned by a machine shop .I presume they polish the surface and check or replace the bushings . This should be done to the existing rockers even if the original cams are repaired(Build up and regrind) unless rockers are removed and replaced on the lobes they were running on already.
1995 993 coupe
2012 Boss 302
Old 04-26-2004, 03:08 PM
adomakin's Avatar
cheers john
Andy
Andy
Old 04-27-2004, 08:20 AM
