Nitrometano's Avatar
Question Weber Taller Secondary Venturis
Hi,
My 1972 911T have a 2.4 engine with 40 IDA Webers, MSD 6A, Crane Cams XR700, Blaster 3 coil, Bursch headers.
I can replace the stock secondary venturies for the taller secondary venturis? How the change of venturies can affect the performance?
Thanks,
Nitro
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 10-26-2004, 10:12 PM
jluetjen's Avatar
How (will) the change of venturies ... affect the performance?
I doubt that it will at all given your engine configuration. The key factor is the cam design (forget about all of the electronics for now) -- I assume that you still have T cams?
My understanding is that the tall secondaries help the part throttle response when you're running long duration cams with significant overlap. So the tall secondaries may help if you had S cams, but for T's, I doubt that they make a big difference.
Can anyone else confirm or deny my understanding?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-27-2004, 04:30 AM
I would rather be driving
jpnovak's Avatar
I agree. I think it typically lengthens the vacuum runner length on the main carb jets. This helps smooth out the airflow from the reversion of high overlap cams. Reversion is usually only a problem at low engine speeds which usually occur at part throttle. Using the tall manifolds serves the same function. An analogy would be the RSR high butterflys for MFI and moving the injectors to the top of the stack.
Old 10-27-2004, 07:52 AM
Really I don't know if the engine have another cams. I own the car since 7 years and I never repair the engine. I found in the papers that in 1976 2.4S pistons installed. Since that, I don't find another part replacement until 1998 hydraulic chain tensioner was installed. I notice that some flat spot exist between 2,000 RPM and 3,800 RPM. And I was thinking is the taller secondary venturis will help to reduce or eliminate that flat spot.
1972 911T
Old 10-27-2004, 07:50 PM
jpnovak's Avatar
A flat spot can probably be diagnosed as improper float levels. Or you are running lean on your idle circuit.
The S pistons will clear the cams. The only way to tell is to measure them using a degree wheel and a dial indicator. map the intake and exhaust and post the results.
Old 10-28-2004, 07:26 AM
I have the dial indicator, but I dont know how to use the degree wheel on the engine.
What I need to measure the float level?
1972 911T
Old 10-28-2004, 05:05 PM
jpnovak's Avatar
If you have Wayne's 101 projects book it details a way to meaure the float levels. Another way is to buy a float level guage. You can get one on ebay or from PMO carbs.
A degree wheel will attach to the end of the cam. YOu take a lift reading starting from TDC every 10 deg or so. This will create a graph. You can determine the type of cam based on the max lift value, the duration (width of the curve) and the degrees of overlap.
Old 10-28-2004, 05:46 PM
