Wrist Pin Clips
Is it unwise to reuse piston wrist pin clips?? I lost two somehow, but have some from the old PC set. They seem fine and w/o weakness. If not wise, does anyone have a couple they could send me??
15014 Penn Hills Houston, TX 77062 |
Bob,
I would not re-use. You should be able to find some new ones at Bap-Geon or one of the other specialty shops locally. |
I re-used the good ones and ordered replacements on the bad from our host. They don't have them in a catalog but were able to source for me. There's not a whole lot of pressure on them to push out.
I have always reused the clips, as long as they still have sufficient tension to snap back into place they will work just fine.
Why would anyone re-use such an inexpensive, yet critical part?
Pro-builders would never do it. |
Ask Tyson Schmidt about reusing wrist-pin clips...
| All times are GMT -8. The time now is 03:08 AM. |
