-   -   Can I use 3.6 turbo pistons and cylinders on my 3.3 turbo (http://forums.pelicanparts.com/911-engine-rebuilding-forum/162015-can-i-use-3-6-turbo-pistons-cylinders-my-3-3-turbo.html)
adomakin 05-07-2004 01:21 PM
can i increase the cubic capacity of my 3.3 turbo to 3.6 by using pistons and barrels from a 3.6? i understand that ill have to use a low comp piston but, assuming the 3.6 barrels fit, would i have to run the same compression as the 3.3 turbo? is it as striaght forward as that or would i need 3.6 heads etc?
Andy
vichang4 05-07-2004 09:27 PM
I always thought the 3.3 case needed to be modified to fit the 3.6 P & C.
-Vic
adomakin 05-08-2004 01:08 AM
is that right? hmmmmm......
WERK I 05-08-2004 01:49 PM
You have to include the 3.6 crank too. The 3.6 turbo is a bored and stroked 3.3. To fit the 3.6 crank, some of the case has to be grinded slightly to clear the throws.
adomakin 05-08-2004 02:47 PM
thanks blokes, 3.3 it is then!
Porschephd 05-08-2004 09:17 PM
You could use 100mm and be at a 3.5 setup. I will not bore a 3.3 case for 100s. The spigots become to thin and will cause issues down the road and certainly will leak. You can go the old way and use liners like Andial did. The most I will open those up to are a 98mm which require no machining to the case. That and a half of point bump in CR and you are set for a nice running car. Don't forget the twin plug for that added heat, I mean HP :D
adomakin 05-09-2004 12:12 PM
cheers steve, you are a very helpfull man!
