-   -   Help - valve spring height for elgin sc330 cam (http://forums.pelicanparts.com/911-engine-rebuilding-forum/162932-help-valve-spring-height-elgin-sc330-cam.html)
nreed 05-13-2004 07:55 PM
Bruce Anderson's book recommends 34.5 as a valve spring height on both intake and exhaust. Is this correct for a 930 with elgin sc330's?
Also, the springs I have are wound closer on one end (more turns per inch). Does it matter how they are installed? I assume that the closer wound end goes to the head????
Thanks,
