369 lb-ft @5700 rpm is nothing to sneeze at....
at 2000 rpm its probably got a higher torque output than a NA 2.0...at 3000 rpm its probably got more torque than a 2.0 911S...at 4000 its probably got.... etc.. Choose a proper cam, time the cam approprialtely, combine with some of the new efficient turbos and you could have a wicked small displacement turbo engine. Ive been squireling away parts to buil a similar engine for years.. I have a set of iconel 935 header, TWM throttle bodies, GT3 oil pump etc... I think ill stick it in my 914, instead of my 911 |
Hold your head
[QUOTE]Originally posted by beepbeep
problems with 911 engines with high boost are twofold: They have individual heads which is worse when it comes to keeping "lid" shut when combustion occurs. Watercooled cars have one head per cylinder bank which means that there are many studs keeping it in the place. When combustion occurs (and it's almost always only one cylinder at a time per cylinder bank), head will be kept in place not just by head-studs surrounding that particular cylinder but by the adjacent ones too. Being single-piece cast object, that head will tolerate more boost before it starts leaking. 930 head, for example, is kept there by only four studs and will start "walking" when subjected to high boost. [QUOTE] Supertec Head studs will reduce and under certain circumstance eliminate head movement. One customer is running our head studs at 45 ft/lb of torque. Although we don't recommend head torque in this range it seems to work with his 700+ hp. Watch for the SUPERTEC HEAD STUD KIT on the pages of Pelican parts soon. http://forums.pelicanparts.com/uploa...1085785571.jpg http://forums.pelicanparts.com/uploa...1085785621.jpg |
Full boost won't be achieved until 4400 RPM though :-) That's the price you have to pay when using big turbocharger. We'll see how good my estimate works in practice. Quote:
Speaking about chamber design, domed pistons are usually big no-no when it comes to knock resistance. You want your combustion chamber free of sharp edges and slightly spherical. This is little easier to achieve when you have four small valves instead of two big ones. Quote:
Cheers! |
PS Goran I don't have time to respond now but I will later, your reponses are again very interesting. |
| All times are GMT -8. The time now is 11:35 PM. |
