2.5 liter on a later aluminum case
Can a 2.5 liter short stroke be built with a later 3.0 or 3.2 liter aluminum case?
From reading the thread this would be the 66 mm counter weighted crank with the early 2.0 rods. |
The quickest, easiest, cheapest motor you can build goes like this:
70.4mm crank (dime a dozen) 84mm pistons from a 2.2E Solex cams SC oil pump All of these parts are dirt cheap used in good shape and makes a nice high compression, eminently fun motor. You could find the parts quick, assemble it quick and have fun quick for far less than most combos. |
Kenik... can you elaborate a bit further on what else to do with your suggestion ??
I presume mfi for induction since you recommended using "E" heads ?? OR plug the holes & run carbs ?? (mfi ain't cheap so am I missing something here ??) Lastly, what about timing (6 or 12 plug dizzy or something else ?? ) & exhaust to use ?? If one were to make this set up, what ballpark hp are we talking ?? ...I think I am about to drop some coin here... Thanks for your input here!! Bob |
woops... sorry I missed that you recommend 84mm pistons from the 2.2E... so what does this mean for heads ??
Thanks again! Bob |
http://forums.pelicanparts.com/porsche-911-technical-forum/447706-1975-2-7s-carbs-hp.html |
| All times are GMT -8. The time now is 02:06 AM. |
