-   -   Big end rod width on 3.2/3.3? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/164643-big-end-rod-width-3-2-3-3-a.html)
David 05-25-2004 06:29 AM
According to Wayne's book, in 1986 Porsche changed the big end connecting rod width from 21.70-21.80mm to 21.85-21.90mm and they closed up rod sidewall clearance from .200-.350mm to .100-.200mm. Would it be safe to assume that a replacement rod for any 3.2/3.3 from 78 on should be the wider rod that closes the gap?
Henry Schmidt 05-25-2004 06:37 AM
If the side gap is too small, proper rod bearing oiling is impaired. That said if the factory reduced the gap, your assumption seems sound.
