-   -   Replacing head studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/165832-replacing-head-studs.html)
rotorhead 06-02-2004 02:15 AM
A bit of advice please guys,
I have an 1988 930, it has an oil leak from the join between the #5 cylinder and the block. The leak is bad enough to be refused a roadworthy certificate so I need to fix it.
I am guessing that it is probably a broken head stud (after reading similar posts, but I will confirm it). If it is a broken stud head stud I plan to replace them myself. I would prefer no advice like "while you have it out rebuild the entire engine" as the car has only 30k on it.
I am planning to remove the engine and remove the P&C then replace all head studs with steel 993 studs, then replace the P&C as a unit. I figure this to be the most straight forward method.
any constructive advice is welcome (such as checking the case to see if it needs to be machined, check the valves....)
I have all of Waynes books, the Bentley, the Haynes, and the Factory Worksop Manuals.
Thanks in advance
also, can anyone tell me which gasket kit I will need for this?
Porsche_monkey 06-02-2004 06:40 AM
Why remove the P&C's on a 'good' engine with 30K? What is your compression on the other cylinders?
hobieboy 06-02-2004 06:43 AM
From everything I read & folks I asked, there's a very good chance you'll have to split the case to extract the head stud as high heat is required; particularly if the stud is broken.
Before you do anything, I'd do a leak down to see the health of the top end. And after you opened up the top end, I'd at least check the valve guides, condition of cam & rockers.
rotorhead 06-02-2004 07:20 AM
I had a leakdown done recently and the figures are good for all cylinders (within 2% across all cyls). I believe that there is no problem with the top end (Inspection will tell) I may have a little valve guide wear as I get a puff of smoke on start if the car has sat for a while.
I believe that I have to remove the P+C to change the head studs (source Waynes Books)
Also does an 88 3.3 turbo have Alusil or Nikasil Cylinders?
hobieboy 06-02-2004 07:24 AM
Yes - the P&C needs to come out.
Porsche_monkey 06-02-2004 07:28 AM
Personally, I think you're getting way ahead of yourself.
rotorhead 06-02-2004 07:38 AM
OK that may be true but the oil leak is comming from between the cylinder and the case on the #5. I feel pretty safe in assuming that I will have to remove that Cylinder. I do not know if it is a head stud yet, but I understand that I should probably replace the divilar studs with steel anyhow.
Porsche_monkey 06-02-2004 07:41 AM
If it needs to come apart pull the wrist pins and leave the pistons in the cylinders.
If you post your progress/questions as you go you will find lots of help here.
Superman 06-02-2004 08:01 AM
Wrist pins can be stubborn, so I suggest using heat. They are MUCH easier to remove from a warm piston than a cold one. Once the P&C's are removed, then you'll have access to the stud area. Hopefully they are all long enough to get a pair of pliers on. Use oxy-acetylene. Trust me on this one. Rent a unit if you have to, but don't mess around with flame that's not hot enough. After perhaps a minute of heating, they will come out. Keep heat on them and turn smoothly until it's out.
As much as I hate to say this, you might want to use the current-generation of Dilivar studs to replace. Your engine makes more heat than mine, and those Dilivar studs may be a good application for your engine. Maybe someone understands this better than I.
john walker's workshop 06-02-2004 08:02 AM
you should not have to split the case to remove the studs. just start out renting or borrowing a oxy/acetylene rig so you can get enough heat in the area in a short (30 seconds) period of time, instead of screwing around with propane or mapp gas for hours with mixed results. a good "while you're in there" (sorry), would be some ARP rod bolts, which can be done without splitting the case.
Porsche_monkey 06-02-2004 08:08 AM
I have 12 new dilivars :) for sale.
rotorhead 06-02-2004 08:22 AM
Sorry PBH you are in Canada, I a m planning on putting a single (Large ish) order in to Pelican to reduce shipping costs.
Superman and JWW thankyou for the tip about the Oxy Acetaline I will do just that. The ARP rod bolts have just gone onto my list (They are mentioned in Waynes book) I did not know that could be done without splitting the case.
Great advice guys :)
Porsche_monkey 06-02-2004 08:49 AM
What has Pelican ever done for us? :)
Wayne 962 06-02-2004 10:45 AM
Hmm, lots of questions. Follow the Engine Book carefully, and also check out the Engine Rebuild Wizard:
http://www.pelicanparts.com/cgi-bin/wizards/parts_wizard.cgi?wizard_root=911_engine_rebuild
Other than that, ask your questions here. As I mention in the book, it's best to tear down your engine to see what you've got to deal with, before you get ahead of yourself...
-Wayne
KobaltBlau 06-02-2004 11:25 AM
Raceware might be worth it on a 930. Do your homework on the studs, and if you are able to take things apart before you order the parts you may save yourself lots. Of course it sucks to have the car down for a long time.
Porsche_monkey 06-02-2004 11:36 AM
Look at Waynes book for labor estimates, figure out how many hours/week you can spend, then figure out how long you'll be off the road. I just spent 6 months of 'down-time'.
Fishcop 06-02-2004 07:27 PM
Steve, I've a few good resources and tools (you've probably got the later cam shafts) at my place. Let me know if I can help. Good excuse to come for a drive to Toowoomba!
As an ex-copper, I recall a few of the "roadworthy tricks" that may get you over the line with an oil leak.... Just how bad is it? I agree that you shouldn't get too far ahead of yourself, there may be another issue other than a head stud.
Cheers
rotorhead 06-03-2004 11:03 PM
Wow thanks for the great response guys! As I get into the problem further I'll post more onto this forum.
John, I will take you up on the trip to Toowoomba let me know when you have a couple hours free and I'll be right over
Doug Zielke 06-04-2004 07:44 AM
I have 11 "used" Dilavars for sale (cheep).
Porsche_monkey 06-04-2004 07:50 AM
You broke a dilivar? Unbeleivable!!
beepbeep 06-04-2004 07:59 AM
Hmm...have you really popped valve covers and checked for broken studs? They might be loose or you might have a case of "uneven mating surface". Quite common problem on 930's.
Interesting enough, it's often nr. 5 that leaks...mine did it too! it must be something with bad cooling/airflow.
David 06-06-2004 09:07 AM
Are you sure it's the cylinder and not the oil return tube? The tubes are notorious for leaking and there are two piece tubes for replacing them with engine still together.
It's pretty easy to pull the lower valve covers and check for broken studs. You should be able to do it in about an hour.
If you do have a broken stud, clean the engine before you pull the heads and cylinders since you don't want to split the case.
If you don't have any broken studs, you could clean the bottom of the engine with it still in the car and go back for the inspection.
rotorhead 06-06-2004 06:31 PM
Great stuff, thanks guys.
The car is in the workshop having some interior work done so I can't quckly check all the great ideas you have given me. It should be back next week and I'll update you all with some photos.
