weber 40
Hi all
will 40idt webers work fine with 2.7L rs spec ?
thanks
philippe
Old 06-04-2004, 12:07 AM
No Expert
jgparker's Avatar
Yes, but you'll probably need to get new set-ups. (Venturies, jets, emultion tubes, etc.) You will not get optimum perfromance out of a 2.0T set-up on a 2.7RS engine. I hear Pelican sells all the PMO/Weber parts, but I can't find any in the search engine. You'll probably need to give them a call. If you'r lucky, you may only need the venturies, the main and idle jets, which should run ~$120. I can post PMO's recomended set-up if you need it.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 06-04-2004, 04:56 AM
thanks
that's just in case of my MFI pump is worn out
philippe
Old 06-04-2004, 12:53 PM
