-   -   MFI Fuel line leak (http://forums.pelicanparts.com/911-engine-rebuilding-forum/166519-mfi-fuel-line-leak.html)
cosmo 06-06-2004 03:35 PM
MFI Fuel line leak
Engine is finally in and cranking but #1 injector continues to leak.
I've tried retighting and even pulled it apart and inspected it several times, both line end and injector look fine but!!!!!!!!!!! It still leaks. Any ideas?? 2.2 MFI :mad:
Henry Schmidt 06-07-2004 07:31 AM
Look for a very small crack. The hard lines vibrate and crack. You can use a fuel injection pressure tester to see where your line is leaking. I have never seen an injector leak so if the seat on the injector is not damaged your problem is the line. We may have a replaement in stock. Call and I'll check.http://forums.pelicanparts.com/uploa...1086618681.jpg
