Question Electric Speedo hookup
I replaced my 901 trans with a 915 and need some help hooking up the electric speedo.
1. I have the round sensor that goes into the side of the trans and it has two wires coming from it, brown and green.
2. There is also a seperate single male connector coming off of the trans.
3. I have the electric speedo that has 4 male plugs across the bottom. 3 together and 1 offset by itself.
Can anyone help me with where these wires go?
I also need Intake manifolds and linkage to install the 40mm Zenith carbs I am replacing my MFI with.
Howard
Old 09-16-2006, 11:29 AM
MBEngineering's Avatar
HI as no one will tackle your bit of wiring I will , the 2 wires from the sensor on the gearbox you will have to run through to the dash , on the back of the speedo you will require a IGNITION live to the + terminal, earth on the _ (should be one of the old speedo) plus one of the wires from the gear box (also to earth on the same terminal) , the other wire from the gearbox is on to the 31b on the speedo , leave the other terminal.
regards mike
Old 09-18-2006, 10:33 AM
