-   -   afraid to start the engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/166778-afraid-start-engine.html)
pierre p. 06-08-2004 07:28 AM
I got the eng two years ago. But didn't started yet. Is it a very bad thing? What should I do and how? Need advice.
THANKS!
Pierre
http://forums.pelicanparts.com/uploa...1086704779.jpg
magic930 06-08-2004 08:21 AM
Crank the engine with the coil disconnected for 20-30second intervals until oil pressure builds (simlar procedure as if its a new engine). Then reconnect and fire it up.
PS. Remove those fancy custom spheroid air filters first:)
pierre p. 06-08-2004 08:53 AM
Thanks magic930,
But that's it? no need to put any gas in the carbs? just pump it?
Pierre
( wilson tennis balls ''the best'' :-)
911pcars 06-08-2004 08:57 AM
Remove spark plugs and squirt some oil in the cylinders, then rotate the engine by hand to verify it can rotate. While you're there, perform a compression test and record readings. Reinstall plugs. If everything is okay so far, try to start it. Carbs may be be gummed up from storage in which case the engine may not run well or at all. Check for adequate fuel pressure and spark too.
Best wishes,
Sherwood
http://members.rennlist.org/911pcars
magic930 06-08-2004 09:06 AM
Not sure about that, someone else will have to answer that one.
pierre p. 06-08-2004 09:09 AM
Thanks Sherwood,
I will do the operations this afternoon.
I appreciate guys!!!
Pierre
pierre p. 06-08-2004 09:15 AM
E!!!
I'll wait, but guys all your advices make sences for me.
garibaldi 06-08-2004 09:31 AM
Take out the tennis balls and go play a few sets of doubles first.
Groesbeck Hurricane 06-08-2004 10:11 AM
A thimble in the carbs would not hurt if you were going to just start her straight away, but you do not want to start the vehicle until after the oil pressure has been built up per Magic. By the time you are through doing everything suggested by Sherwood and Magic, there should be plenty of fuel in the carbs.
Bonne Chance!!
pierre p. 06-08-2004 10:42 AM
ho! about fuel,
I have to drain everything and use new one?
merci David
Pierre
Groesbeck Hurricane 06-08-2004 10:54 AM
Pierre,
You do not need to drain the fuel. After you have been turning over the motor to get the oil pump primed per Majic's suggestion the fuel pump will have already started pumping fuel into your carbs. This should suffice to prime the carbs and prepare your car to start.
C'est rien! J'espare que tous vas bien passe!!!
Eagledriver 06-08-2004 12:02 PM
If the fuel is 2 years old you may need to dilute it with some fresher fuel to get it to start.
-Andy
beepbeep 06-08-2004 12:33 PM
If fuel is 2 year old and tank is half empty, fill it with fresh fuel.
Wayne 962 06-08-2004 12:44 PM
Don't use any 2-year old fuel. Tap into the line and flush it out. Today's gasoline doesn't store very well.
Take a close look at your carbs - the floats may be stuck closed. Don't run any fuel through them though, until you've cranked the engine a few times and built oil pressure. Make sure that you change the oil first too.
-Wayne
KobaltBlau 06-08-2004 12:55 PM
Definitely do what Sherwood and Wayne said, it's good advice.
pierre p. 06-08-2004 01:17 PM
Ok,
I changed the oil already and now going to flush the gas tank.
I dont want to take any chances.
I'm taking notes and going to fallow all the advices.
Thank guys!!!
Pierre
KobaltBlau 06-08-2004 01:19 PM
When you flush the tank check to make sure there is no crap coming out of it, as best you can.
Wayne 962 06-08-2004 11:24 PM
I remember one 914-6 that I bought. It had been sitting for quite some time. The needle valves on the carbs were stuck open. When I turned the thing on, fuel came right out of the top of the carbs and spilled all over the engine. Surprised the heck out of me. Good thing I didn't try to crank it just then...
-Wayne
smestas 06-09-2004 02:50 AM
I think a fire extinguisher upon start up wouldn’t be a bad idea.
