up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Woodruff Key Removal?
I don't know what's different about this engine, but upon teardown, the woodruff keys did NOT want to come off. Finally got one off, but the other is still on it! Never seen this before... Any suggestions? I've already tried a crowbar
Scott Kinder
kindersport @ gmail.com
Old 07-22-2004, 05:33 PM
Now in 993 land ...
aigel's Avatar
You need slight impact, creating vibration, not steady force. A chisel and a small hammer should break it loose. A bit of heat won't hurt either, but dose it carefully.
George
81 SC (sold)
Old 07-22-2004, 06:03 PM
crank or cam key? generally you just use a hammer and punch. on the cam key, just a light tap on the end rocks it out of the slot. on the crank key, punch one end downward into the keyway, which raises the other end. keep tapping and it will roll right out of the keyway, which has a rounded bottom just like the key.
206 637 4071
Old 07-22-2004, 07:14 PM
YTNUKLR's Avatar
Cam key, sorry. I've torn down several 911 engines but this one just seems to be glued in or something, it's really a PITA! With heat, you mean heat the key, right? Is propane hot enough?
Scott Kinder
Old 07-22-2004, 08:55 PM
Now in 993 land ...
aigel's Avatar
Propane will do. I'd heat the key, just to unsettle things and get rid of any epoxy (loctite) that some clown may have smeared in there. I'd leave the heat off the cam itself. Of course you need to wait for things to cool down before you try again.
You would have to heat the cam to make the hole bigger, but I'd be shy about that. Getting that to a reasonable temperature may change the material properties...
George
81 SC (sold)
Old 07-22-2004, 09:15 PM
Grab tightly with some diagonal cutters, then rock the jaws to lever the key off. If needed, replace the key.
Sherwood
Old 07-22-2004, 10:47 PM
oneblueyedog's Avatar
I had to destroy my key on 123 bank. Got a replacement. I used a punch and hammer. Be careful not to ding the washers.
Lee78sc
78SC coupe, Silver Metallic
Old 07-22-2004, 10:53 PM
