Siena911's Avatar
Cracked Crankshafts?
What is the danger in re-using a cracked crankshaft? i.e. what could happen if you did?
Don't get me wrong, I would never re-use my cracked Crank, I just wanted to know what the effects could be.
Another thing, what would cause the cracking in the first place? Is it heat?
My engine ran a bearing and the crank tested positive for cracks so I was just wondering if the cracks were there for the last 10000 miles?
Any thoughts
cheers Jakes
p.s. Moderators if this is meant to be in the normal forum, feel free to move it
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 06-16-2004, 01:56 AM
jluetjen's Avatar
As long as they were just minor cracks I doubt that you would notice any outward symptoms or issues. The problem is that small cracks grow into big cracks and big cracks grow into breaks. If you're crankshaft breaks you will have major problems and a pile of expensive metal parts that used to be a motor.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-16-2004, 04:49 AM
