-   -   Wayne - 204hp SC Pistons & Barrels in Carrera 3.0? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/168049-wayne-204hp-sc-pistons-barrels-carrera-3-0-a.html)
OZCarrera3 06-16-2004 06:35 PM
Hi Wayne,
I've moved this post from Tech Forum (should have been here in the first place I know).
As mentioned in a
P=previous thread, I'm about to replace the pistons and barrels in my engine and was hoping to upgrade to the later 204hp SC high compression units to boost performance.
I have been told that I can do this without making any other modifications to the engine. Can you please confirm that this is the case? My main concern would be the cams, which I understand are different to those fitted to the SC. Also do you think this would have longevity issues for the engine?
Wayne 962 06-16-2004 10:50 PM
Yes, the Euro pistons can be used instead with no mods...
-Wayne
OZCarrera3 06-16-2004 10:56 PM
Great! Thanks Wayne.
Was concerned that there may have been changes required to the cams, timing chains, CIS or ignition.
