I was not paying attention when I took it out. Its a 79 SC. I want to make sure the throw out bearing parts are in the right order.
TIA
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Erik;
sent you a PM. thanks! jerry
Unclear on the concept ? Let's see if I can help. 1) You are NOT in the "fast lane" and... 2) You are NOT going "fast enough". **News Flash** You're in the Passing Lane. Any questions ? |
thin flat ring first, then the cupped notchy springy thingy, cup facing you, set the p/plate over it, then the thick ring, inner groove facing you, push down and install the snap ring.
Thanks John!
I just broke my damn fly wheel bearing, Put it in back wards and when I pushed it out it smunched!!! Hope I can find one local I want to put this together this weekend....
