911 OCD
jpkelly3's Avatar
CO and timing advance settings
I have an 83 SC USA motor with ROW CIS intake. Car is primarily used for DE. What is optimal CO and timing advance settings for best HP? Everything is stock except for GHL headers and muffler. Thanks in advance.
John Kelly
jk
82 SC Euro 82 SC Targa 69 912 62 AH 3000 97 740il
'If you are under control, you're going too slow'
Parnelli Jones
Old 04-07-2007, 06:38 AM
Hi John:
CIS offers VERY limited abilities to alter CO beyond idle, but I'd shoot for 2.5% CO using headers and low restriction mufflers. Without question, you should check your AFR's on a chassis dyno to make sure you are not too lean above 5000 at WOT.
Assuming that you are using 93 octane pump gas, stick with stock advance numbers so you do not inadvertently buy new P/C's,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-07-2007, 02:04 PM
911 OCD
jpkelly3's Avatar
Settings
Thanks loads Steve.
jk
Parnelli Jones
Old 04-07-2007, 02:26 PM
911 OCD
jpkelly3's Avatar
Stupid Question, I know....What is WOT?
Thanks again
jk
Parnelli Jones
Old 04-07-2007, 02:29 PM
Thanks again
Not stupid at all,......
Wide Open Throttle
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-07-2007, 02:56 PM
911 OCD
jpkelly3's Avatar
I may be a little lean as the car has been running on the hotter side at DE events. So this info is very good to know. I'll also keep my 3 mm allen as a mainstay track tool.
Have a good holiday
jk
jk
Parnelli Jones
Old 04-07-2007, 03:58 PM
